There is a fundamental difference between YUY2 or UYVY on one hand, and YV16 on the other hand: "packed pixel" vs. "planar" ordering of luminance and chrominance components across a frame. But this difference is only interesting for programmers...
Results 31 to 36 of 36
So according to the Avisynth wiki here:
http://avisynth.nl/index.php/Sampling
v2.6 natively supports 4:1:1 DV. Would it be better for me to upgrade to v2.6, so I have complete control how to upscale my 4:1:1 DV to 4:2:2? For example, something like:
Code:ConvertToYUY2(interlaced=true,chromaresample="spline36")
This is a puzzling/frustrating.
Here is what is reported for the above formats:
AviSource(V).Histogram(mode="levels").Info() = YV12
Deleting Histogram():
AviSource(V, pixel_type="RGB24").Histogram(mode="levels").Info() = ERROR: Histogram Levels mode only available in PLANAR
AviSource(V, pixel_type="YUY2").Histogram(mode="levels").Info() = ERROR: Histogram Levels mode only available in PLANAR
AviSource(V, pixel_type="YV12").Histogram(mode="levels").Info()[/list]= YV12
AviSource(V, pixel_type="RGB24").Info() = RGB24
I guess I shouldn't be too surprised it defaults to YV12 since according to the AVISource wiki, YV12 supersedes YV411. But what I don't understand is why can't Avisynth open my DV when pixel_type = YV411. I checked my Avisynth install and I have 2.6 installed. And the supposedly v2.6 natively supports 4:1:1 content.
AviSource(V, pixel_type="YUY2").Info() = YUY2
AviSource(V, pixel_type="YV411").Info() = ERROR: AVISource: the video decompressor couldn't produce YV411 output
AviSource(V, pixel_type="FULL").Info() = YV12
Any ideas what might be the problem?
Here is the mediainfo of the file:
EDIT: Well, I think I might have found the reason. After downloading vcswap and opening up the configuration dialog for Cedocida there is no option for YV411 in the Decoder section. Am I interpreting this correctly?Code:General Complete name : D:\video.avi Format : AVI Format/Info : Audio Video Interleave Commercial name : DV File size : 181 MiB Duration : 50s 117ms Overall bit rate mode : Constant Overall bit rate : 30.3 Mbps Video ID : 0 Format : DV Codec ID : dvsd Codec ID/Hint : Sony Duration : 50s 117ms Bit rate mode : Constant Bit rate : 24.4 Mbps Encoded bit rate : 28.8 Mbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Original display aspect rat : 4:3 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:1:1 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357 Time code of first frame : 00:00:46;05 Time code source : Subcode time code Stream size : 172 MiB (95%)
[Attachment 36005 - Click to enlarge]Last edited by SameSelf; 4th Mar 2016 at 20:47.
Your VFW decoder doesn't support 4:1:1. A VFW decoder is used when you use AVISource(). If you're using cedocida it's not an available option . It's probably the best choice when using AVISource() . FFMS2 and L-smash do support 4:1:1 . As for what to use - do some comparisons for your specific scenario. The benefit probably isn't worth the indexing time (and "pollution" as you eloquently put it) in most scenarios for DV
I don't think there's any VFW DV decoder that supports any form of YUV 4:1:1 output.
pdr and jagabo, I think I agree with you both that no VfW DV decoders output YUV 4:1:1. Trouble is, testing is just that. Maybe stuff works, maybe it doesn't. I downloaded most major VfW DV AVI decoders: Cedocida, Canopus, Avid, GV (did I miss any?). None output 4:1:1, if they even load the clip at all. So, I moved on FFMS2 and L-SMASH.
FFMS2 is very buggy as well. v2.22 that the Avisynth wiki links to here decodes my video green and upside down. When I roll back to v2.21, the green and flip go away, but the output is YUY2 (or was it YV12?), sigh. I ended up having to download a build posted on doom9 here. This appears to work i.e. properly decoded video (no green or flip) and YUV411 output.
Also, VirtualDub doesn't play nice with L-SMASH or FFMS2. I had to switch over to AvsPmod for testing which is better anyway, so I guess it was inevitable. But the initial problems led me to believe L-SMASH wasn't working either. It wasn't until I removed vdub from the chain and did a test encode in ffmpeg that I realized that L-SMASH does indeed work. The same problems occur with FFMS2. If there is configuration that I am missing in vdub, I am interested in knowing.
Bottomline, I have two methods to output YUV411 video now. All this testing has given me a bunch of different ideas and added tremendously to my understanding of video. I can't say with 100% certainty that decoding video with indexing as YUV411 will be better than AviSource() with a VfW DV decoder. But the real fun is about to begin. As for drive "pollution," that's what batch files are for, amiright?
Full range(0-255)colors of x264 doesn't work in FFMPEG-based softwares
By Stears555 in forum Video ConversionReplies: 1Last Post: 17th Apr 2014, 10:07 -
DVDFab maintaining decryption functionality?
By leghorn in forum Blu-ray RippingReplies: 2Last Post: 13th Apr 2014, 13:02 -
Proper Resizing and maintaining aspect ratio with Avisynth
By Radio Radio in forum Newbie / General discussionsReplies: 39Last Post: 11th Apr 2013, 14:43 -
Does FFV1 and Huffyuv support full-range (0-255) color or limited TV 16-235
By Stears555 in forum Video ConversionReplies: 11Last Post: 27th Dec 2012, 16:15 -
YCbCr 16-235 to RGB 0-255 and PAL/NTSC differences (7.5 IRE)
By intracube in forum Video ConversionReplies: 11Last Post: 5th Sep 2011, 05:39
